ioBridge Community
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
SMF - Just Installed!
Home
Help
Search
Login
Register
ioBridge Community
Hardware
Interface Boards
DPDT Relay Board - Function Board
« previous
next »
Print
Pages: [
1
Author
Topic: DPDT Relay Board - Function Board (Read 1901 times)
Jimmy
Newbie
on:
March 08, 2009, 06:40:04 AM »
Don't know if anyone has had much to do with the Relay Board Function Board, but according to the spec sheet, it appears to handle 240v AC. Is that correct? Can I switch 240 volts through this tiny function board?
Thanks.
Logged
Full Member
Re: DPDT Relay Board - Function Board
Reply #1 on:
March 08, 2009, 11:29:56 AM »
Note that it's only rated for 5 amps. In the US at least almost nothing that runs over 120V draws that little current.
Logged
Jimmy
Newbie
Reply #2 on:
March 08, 2009, 06:51:03 PM »
I did see it was only rated for 5 amps, which is fine for my use switching some lighting. But will it handle 240 volts?
Logged
Administrator
Hero Member
Reply #3 on:
March 08, 2009, 07:13:31 PM »
I've run 120v through one here to light a few incandescent bulbs.
If you do run 240v through it, make sure you are very careful about the exposed traces on the bottom of the relay board.
Last Edit: March 08, 2009, 07:17:57 PM by jason
Logged
Jimmy
Newbie
Reply #4 on:
March 08, 2009, 08:05:01 PM »
I'm always very careful with mains power as I've been 'stung' by it a few times as a kid. But as long as it handles 240 without any problems then I'm going to order a board now.
Thanks.
Logged
Full Member
Reply #5 on:
March 08, 2009, 10:33:52 PM »
Here is a datasheet for the relay:
http://relays.tycoelectronics.com/datasheets/p2.pdf
The data you need is on page 9. Maxing switching capacity is 60 watts. The 5 amp figure is peak, maximum sustained current is 2 amps.
Probably not terribly useful for lamps.
Logged
Administrator
Hero Member
Reply #6 on:
March 08, 2009, 11:06:04 PM »
If it helps, here is the schematic of the relay board. Its a fairly simple circuit. You could probably make you own capable of higher power if you wanted.
You did make a pretty cool setup back in this post:
http://www.iobridge.net/forum/index.php/topic,255.0.html
Another option is a "solid state" relay. They are a bit more expensive but may be better for your situation. Most have screw terminals so you don't even need to do any soldering. I've never personally used one, but looking at the specs, an IO-204 could drive one directly from it's digital output.
Here's an example:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=PB545-ND
Logged
Full Member
Reply #7 on:
March 09, 2009, 11:39:57 AM »
I've had good results using the Functional Devices "Relay in a box" (RIB)
http://www.functionaldevices.com/pdf/RIBU1C.pdf
What I like is that they come in a UL-listed housing that attaches to a standard junction box so you can use them in a code-compliant way. It's also interesting that they have both a high-voltage and low-voltage coil in the same unit.
You can get them on Ebay for about $15.
What you could do is use the ioBridge relay to power this relay. The one question is what voltage level to use. There is a version of the RIB that uses 240VAC for the coil, the RIBH1C, which you could switch with the ioBridge relay. I think it would be safer to use the low voltage coil of the relay. The problem is that it takes a minimum of 10V for the low voltage coil so you would need to add another power supply.
Logged
uknative
Newbie
Reply #8 on:
February 21, 2010, 08:56:48 PM »
I see on the circiut schmeatic there is a "2222" transistor, would it be possible to substitute a "3904" transistor?
I only ask because that is what I have on hand, and I have a grab bag full of relays that I got a while back.
Logged
Administrator
Hero Member
Reply #9 on:
February 22, 2010, 09:08:24 AM »
I would think a 3904 would drive most small relays (> 100mA). A 3904 is an NPN transistor therefore it will work with the circuit above. Be careful trying to drive a large relay with it. I'm not sure how much current they can handle.
Logged
uknative
Newbie
Reply #10 on:
February 22, 2010, 09:51:37 AM »
Thanks Jason. It is a small relay (5v coil) almost exactly the same as the one on your relay boards. I'll let you know how it goes.
Logged
Print
Pages: [
1
« previous
next »
ioBridge Community
Hardware
Interface Boards
