The X10 interface board uses a 6 pin rj11 that is intended to connect to the PSC04. I don't have a PSC04, I have a CM11A. I was hoping to use my iobridge X10 interace board with the CM11A.
The CM11A is an X10 unit that is designed to interface with a computer through RS-232. The CM11A takes a 4 pin RJ11 input and I was assuming that the iobridge X10 controller would interface with it.
After reading the specs on the PSC04 it looks like the PSC04 uses some communication protocol based on the powerline's zero crossing. (and is totally unrelated to the RS232 protocol expected by the CM11A.) If so, then am I correct to assume that iobridge X10 interface board is incompatible with the CM11A?
