ioBridge Community
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
SMF - Just Installed!
Home
Help
Search
Login
Register
ioBridge Community
Announcements
Announcements
16x2 LCD Display
« previous
next »
Print
Pages: [
1
Author
Topic: 16x2 LCD Display (Read 2100 times)
Administrator
Hero Member
16x2 LCD Display
on:
April 30, 2009, 10:43:34 AM »
We have a new LCD display available in the store. It can plug directly into an I/O channel or an extension cable and is controlled by a "serial output" widget. Although it's our design, it could be used with other micro-controllers since it accepts commands via serial (9600,8,N,1).
There is more information about the new LCD display on the wiki.
http://www.iobridge.net/wiki/function-boards/serial-lcd
Logged
Outlet
Newbie
Re: 16x2 LCD Display
Reply #1 on:
May 03, 2009, 06:11:51 PM »
Nice! Do you have any suggestions for an enclosure?
Logged
Administrator
Hero Member
Reply #2 on:
May 04, 2009, 12:37:07 AM »
Sorry, I haven't thought ahead that far. The serial PCB does have 4 mounting holes in the corners. I need to get a mechanical drawing up for the LCD...
Logged
Administrator
Hero Member
Reply #3 on:
June 11, 2009, 11:36:58 AM »
Demo of Serial LCD:
http://www.youtube.com/watch?v=RHmgAxYSsI8
Arduino Library:
http://www.arduino.cc/playground/Learning/ioBridgeSerialLCD
Logged
SL4P
Newbie
Dimensions ?
Reply #4 on:
August 03, 2009, 06:38:41 PM »
Hi - What are the overall dimensions of the LCD module?
I couldn;t see them listed on the LCD page
Will it fit in a standard 1U rack panel... ? (max about 38mm available)
- great functionality - thanks
cheers
Logged
Administrator
Hero Member
Reply #5 on:
August 03, 2009, 08:03:40 PM »
The LCD is 80mm wide and 36mm high. The only problem is the header pins stick out by an extra 10mm. It would be possible to re-solder the header so it sticks out the back instead of the bottom.
Logged
Print
Pages: [
1
« previous
next »
ioBridge Community
Announcements
Announcements
16x2 LCD Display
