Author Topic: Projects?  (Read 826 times)
Tyler
Projects?
« on: June 02, 2009, 03:54:10 PM »
Are there any projects that I can do with out a function board or a smart board?
Re: Projects?
« Reply #1 on: June 03, 2009, 05:04:31 AM »
You should be able to drive an LCD direct from the iobridge module using the serial i/o out. or connect your own analogue devices directly, or just some switches and LEDS might be a simple way to get started.
Re: Projects?
« Reply #2 on: September 20, 2009, 11:53:52 PM »
a thermocouple would also be able to be connected.
anything that uses 5 volts or less would also be able to be connected to a digital out and ground line. i have a buzzer hooked up to one of the digital outs on my iobridge.
you can activate momentary buttons by soldering wires to the button and using a digital output pulse.
also, pwm cables have the correct spacing for connecting to the iobridge
