Author Topic: Changing TTL to Standard RS232 Voltage Levels  (Read 1604 times)
webbr
« on: July 13, 2009, 10:50:09 AM »
Hey,
On the wiki it mentions that the Serial Smart Boards operates on TTL voltage levels, and that the TX pin cannot communicate with a board that does not accept +/- 5 Volts. Has anyone been able to find a way around this problem? Are there any adapters anyone would recommend?
 I really need the smart board to send strings at standard RS-232 voltages (for the device I am using I think I can get away with 8 volts instead of 12).
xzolian
Re: Changing TTL to Standard RS232 Voltage Levels
« Reply #1 on: July 13, 2009, 12:25:44 PM »
You need a driver. Try this one:
http://focus.ti.com/lit/ds/symlink/max232.pdf
« Reply #2 on: July 13, 2009, 05:43:35 PM »
Have you actually attempted it yet?  I've had success with the Serial Smart Board interfaced to standard (non TTL) serial ports.
