Author Topic: Monitoring appliance  (Read 1090 times)
Outlet
« on: July 15, 2009, 04:25:13 PM »
Hello,
Does anybody know the best way to check the power status of an appliance online (whether it is on or off) using the iobridge?  I don't have much experience with hardware (creating circuits, etc).  I would be nice to be able to monitor the electrical draw, or something along those lines.
Thank you in advance!
Silent18
Re: Monitoring appliance
« Reply #1 on: September 21, 2009, 03:52:08 AM »
I think that  they would be nice to be able to adviser the electrical draw, or something forth those lines.
_________________
Ukf8001axx
« Reply #2 on: September 21, 2009, 09:46:06 AM »
assuming you are not using the iobridge to turn the device on and off,
you could use something like this.
http://www.picobay.com/projects/2009/01/real-time-web-based-power-charting.html
however, you will stick the ac clamp on one line of an ac power cord.
« Reply #3 on: September 21, 2009, 07:16:30 PM »
also, if the device has an led that signifies if it is on, you could solder wires to it, and wire it to a digital input
« Reply #4 on: September 23, 2009, 07:26:35 PM »
Or put a photodiode in front of the LED, doesn't even require soldering or opening the case.
« Reply #5 on: September 23, 2009, 08:34:41 PM »
that would work. depends on the conditions however. If the device is working in a place like a kitchen with a lot of light, the photodiode might not be reliable.
EDIT: i also realized: the photodiode will also be a somewhat clunkier looking solution, because the easy way to attach the photodiode would result in probably a poor looking job of taping/gluing. and if you were to isolate the diode, such as using black silicone, it would look bad.
i know id rather of a wire coming out of my appliance, as opposed to glue, but thats me
« Last Edit: September 24, 2009, 02:23:56 AM by zerogx »
