Author Topic: help with servo controller and futaba s3003 settings  (Read 2121 times)
fuser
« on: September 01, 2009, 05:32:42 AM »
as subject ive bought a main board with servo controller connected on port1 and a servo connected on channel 1 of it now my question is
wich setting i need to do for move my servo ?
i must enable digital output or not in modules setup and how i can test the servo movement ( i must create a widget with servo position control where setting deafault range is between 1000 and 2000 ms ) ?
Because i ve tryed to do this and don't work i m waiting for your help tnks a lot  :'( :'(
Re: help with servo controller and futaba s3003 settings
« Reply #1 on: September 01, 2009, 08:24:29 PM »
Is the little green LED lit on the servo board?
http://www.iobridge.net/forum/index.php/topic,24.0.html
« Reply #2 on: September 25, 2009, 12:42:02 AM »
I dont't know if you;ve done this or not... on the module page, the channel with the srrvo controller needs to be set for servo in the drop down box.
You will use a variable or fixed servo widget for control.
claudefrancois
« Reply #3 on: February 27, 2010, 03:47:01 AM »
Hello,
I am a newbie and couldn't find the answer about my question in the forum.
Is it possible (or why not) to make a 360 degree turn with my S3003 servo?
what is the max angle  ?
Cheers
« Reply #4 on: February 27, 2010, 05:01:28 AM »
There are ways to mod the S3003 to make it continuous 360. Requires some soldering.
http://www.ranchbots.com/club/papers/Modifying%20Hobby%20Servo%20Motors%20for%20Continuous%20Rotation.pdf
http://www.instructables.com/id/How-to-modify-a-servo-motor-for-continuous-rotatio/
This makes the servo move in one direction continuously.
