We have implemented the first version of being able to customize the widgets via CSS.
The first go around allows you to change any of the standard I/O monitor widgets. Anything you can control via CSS you can control on the wdiget output - underlines, cursurs, backgrounds, font size, etc.
All you have to do is create a widget and select "Plain Text" as the style. If you already have a monitor widget, you can just select "Plain Text" as the style. The other option is "Default Text" which is the default ioBridge "green theme".
"Plain Text" just gives you the text inside of a span element.
There are two classes you can add anywhere in the page or a CSS attachment. One for the default / load up state and one for the Mouse Over state.
The id's are as follows:
ioData_(widgetID)
ioData_(widgetID)_over
Replace (widgetID) with the widgetID of the widget you want to stylize.
Here is an example of the styles you can add to your page:
<style type="text/css">
.ioData_xGTjqVMJvp {
background-color: blue;
font-size: 100px;
.ioData_xGTjqVMJvp_over {
background-color: green;
font-size: 100px;
</style>
<script type="text/javascript">document.write(unescape("%3Cscript src='" + "http://www.iobridge.com/widgets/io.js?XGTjqVMJvp' type='text/javascript'%3E%3C/script%3E"));</script>
