You should be fine. In theory, even very short connections should be done with twisted pairs. If you split open an ethernet cable you'll see that it's four pairs of wires, and each pair is braided together. Those pairs are supposed to be kept together for as much of the run as possible, all the way up to where the connection is terminated. In practice installers often unwrap them an inch or two before the connection and it works fine.
If you want to take no chances you could make the connection with twisted pairs pulled from an ethernet cable.
You know you only need two pairs to make ethernet work, right?
