This is a feature I've been really looking forward to but I am assuming it hasn't made it to the top of the to-do list yet.
Are general triggers in the works? Maybe triggers is the wrong word, let me explain.
I would like to use my ioBridge as a thermostat.
I would need to to trigger a relay based on the temperature and current time.
(from 5pm - 11pm on at 70F, off at 73F)
(from 8am - 5pm on at 50F, off at 55F)
The advantage of the ioBridge over a home depot thermostat is the ability to override the thermostat from anywhere. When I'm on my way home I reset the thermostat's temp.
Any suggestions? I can see the same capabilities useful for a hot tub. (if you are able to 'prep' the tub for when you get home you could keep the tub at a cooler temp and save $$$.)
