Author Topic: 5V Rails  (Read 657 times)
ohararp
    • OHARARP LLC
5V Rails
« on: December 10, 2009, 11:32:18 AM »
IOBRIDGE, if I were to provide 5V via the channel input pins could I bypass the need for the wall wart?  IE, the IO-204 module would still be able to function properly.  This could be helpful if I were using a seperate AC line to power an 8 channel triac/relay board.
Ryan O'Hara
Re: 5V Rails
« Reply #1 on: December 10, 2009, 12:12:18 PM »
I think that would work fine.
Re: 5V Rails
« Reply #2 on: December 10, 2009, 06:46:31 PM »
it should work. i know hans @ iamshadowlord.com does something similar with his iobridge while traveling. he uses usb power over the terminal board
