Author Topic: Additional channel push update mode option  (Read 570 times)
Travinder
« on: December 15, 2009, 10:30:31 PM »
Is is possible to have the push update mode to include an option for digital state change OR analogue trigger and reset?
Re: Additional channel push update mode option
« Reply #1 on: December 15, 2009, 10:54:59 PM »
I assume you are referring to the 'push update' options that are tied to each individual channel (as seen on the module settings tab).  In that case, it is either one or the other but not both.
However, it is possible to push updates from an analog trigger or a digital state change on a single channel simultaneously.  In order to do this, you will need to create a set of "on-board rules".
This wiki page has all the info on creating rules: http://www.iobridge.net/wiki/onboard-actions
« Last Edit: December 15, 2009, 11:08:26 PM by jason »
Travinder
« Reply #2 on: December 15, 2009, 11:11:44 PM »
wow, a lot of options in on board rules.   I might have to come up with more projects to give these all a try.
