Sorry, we did not close the loop on the forum. This switched over to
support@iobridge.com email.
Our latest firmware allows you to pulse counting directly onboard, then you can push the pulse count every 10 minutes for data logging.
All you have to do is create a data log for the channel that has the reed switch. The channel will set itself up automatically. If interested, the pulse counting is under the Onboard Rules and Actions section of the Module settings tab.
