Author Topic: URL to supply the current time  (Read 1415 times)
jfedison741
« on: January 31, 2010, 04:54:07 PM »
I am using the serial web services API and would like to use [[[get|url]]] to obtain accurate date and time information. I need resolution of seconds (getting the time from the ioBridge server only gives the time to the nearest minute).
Can anyone suggest a URL that gives the current time? Also, the URL needs to respond with fewer than 80 character to satisfy the limits of responses to [[[get|url]]].
Thanks.
Re: URL to supply the current time
« Reply #1 on: January 31, 2010, 11:20:42 PM »
are you looking for local time or greenwich mean time?
jfedison741
« Reply #2 on: February 01, 2010, 09:46:24 AM »
GMT/UTC would be fine.
« Reply #3 on: February 01, 2010, 01:46:06 PM »
http://time-a.timefreq.bldrdoc.gov:13/
Works in my browser.  Haven't tried it with the web API.
It uses the DAYTIME protocol.  More info here: http://www.kloth.net/software/timesrv1.php
« Reply #4 on: February 01, 2010, 07:12:36 PM »
The code for doing the time based on server time:
<html>
<head>
<?echo date('h:i A')?>
 </body>
 </html>
it will need a hosting environment with php enabled.
« Reply #5 on: February 01, 2010, 09:44:54 PM »
<html>
<head>
 </body>
 </html>
That's another alternative.  You don't even have to include the HTML tags, I know the IOBridge will take straight text from a PHP page.
« Reply #6 on: February 01, 2010, 10:18:44 PM »
<html>
 </html>
This is the minimum amount of code needed for keeping with web standards. you would be fine to strip the html. It's not the right way, but you will be fine to do so.
jfedison741
« Reply #7 on: February 03, 2010, 10:25:23 AM »
This works well. Be aware that occasionally the URL does not respond -- In 21 hours of [[[get|URL]]] at 2 minute intervals, I got 9 timeouts. I used a timeout interval of 3500 ms. In cases when the URL does not respond, I leave the timestamp blank and the API uses the current system time.
« Reply #8 on: February 03, 2010, 01:23:22 PM »
If you go to the link they list a whole bunch of other DAYTIME servers, probably one of them is more reliable.  Just make sure to put the ":13" at the end of the URL.
