Author Topic: Real Time Tide Monitor  (Read 1029 times)
capecodda
« on: March 29, 2010, 01:43:37 PM »
My real time coastal tide monitor is described here:
http://capecodgary.blogspot.com/
This project is based on Arduino, ioBridge, and serial spread spectrum radios to hook it all together.
My highest complements to the ioBridge team for making a product that is just unbelievably easy to use.
ryanerb
Re: Real Time Tide Monitor
« Reply #1 on: March 30, 2010, 06:04:32 PM »
Very impressive.  Have you had any battery issues, or is the solar keeping it plenty charged? Are you able to remotely check the voltage?
« Reply #2 on: March 30, 2010, 06:40:51 PM »
Excellent project, great photos.
capecodda
« Reply #3 on: March 30, 2010, 07:06:32 PM »
ryanerb,
We'll see on the battery and solar panel :).   The numbers work (in theory).   It's been up and running since last Thursday only, and we've had some BAD weather here.  I should of course be monitoring the battery with the Arduino but so far I'm not.
ioBridge
Thanks for the complement.  I still cannot believe how easy you made it to get sensor data and the internet connected.
emherrma
« Reply #4 on: April 11, 2011, 01:41:00 PM »
Great project! I am the technical lead on a non-profit dam monitoring project and will be implimenting a similar solution both upstream and down. Might also add a servo control of the flow control gate.
I think I can get away with a long range wifi (enGenius ENG-EOC2611P) for my access to the internet. I have power, so at least that is one technical hurdle that I dont have to worry about.
What I am most interested in is your sketches for the Aurdino board. Seems like you had a little trial and error with the moving tide and signals bouncing off the pier causing inconsistent results in the early stages of your development. I'm sure I will have the same issue. Would like to benefit from your lessons learned in that area. From what I can tell, your compensation algs are built into the Aurdino chipset correct?
I would be happy to share all my results and data with you as well as any improvements that I come up with.
Erik
