ioBridge Community
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
SMF - Just Installed!
Home
Help
Search
Login
Register
ioBridge Community
Hardware
Hardware in General
Analog Inputs negative voltage
« previous
next »
Print
Pages: [
1
Author
Topic: Analog Inputs negative voltage (Read 390 times)
hellpingui
Newbie
on:
June 22, 2010, 05:37:23 AM »
I would like to know if the analog inputs accept a negative voltage (eg -400 mV to 400 mV).
This voltage is provided by a PH probe
thank you in advance for your answers
Sorry for my English
Damien (France)
Logged
Administrator
Hero Member
Re: Analog Inputs negative voltage
Reply #1 on:
July 06, 2010, 09:29:18 AM »
I don't thin that will work. The analog input pin is 0-5v only.
A potential work around is using the +5v and ground pin of an I/O channel to power a 2.5v regulator. Then connect the PH probe ground wire to the 2.5v voltage regulator output instead of the IO-204's ground. This way the IO-204 will measure the voltage range as 2.1v to 2.9v.
There are many 2.5v voltage regulators to choose from. Here is an example:
http://www.national.com/mpf/LM/LM2937-2.5.html#Overview
Logged
Print
Pages: [
1
« previous
next »
ioBridge Community
Hardware
Hardware in General
