Author Topic: Module to Module connection  (Read 393 times)
bgrig
« on: July 19, 2010, 08:42:20 PM »
Could someone please confirm if one iobridge can interact with another iobridge independantly after they have been programmed.    I would like to one module accept inputs and the other module to provide outputs (using the relay board).
Thanks
iobridge
    • ioBridge Support
Re: Module to Module connection
« Reply #1 on: July 19, 2010, 11:37:54 PM »
Module to module connections are made on the server-side. If you have the modules at two different locations, then this would work just fine. Locally the modules are not able to talk to each other directly. They would send the command to ioBridge.com, then back to the other module. The process actually happens extremely fast.
ioBridge Support
Community Team
