ioBridge Community
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
SMF - Just Installed!
Home
Help
Search
Login
Register
ioBridge Community
Hardware
Hardware in General
Using an LM34 temp sensor
« previous
next »
Print
Pages: [
1
Author
Topic: Using an LM34 temp sensor (Read 710 times)
wwtolman
Newbie
on:
July 25, 2010, 08:21:41 PM »
Any reservations I should know about using a LM34 as a temperature sensor with the IoBridge?
I figured using the supplied ground, +5 and Analog input, I should be able to read the voltage for the temp reading.
Logged
wwtolman
Newbie
Re: Using an LM34 temp sensor
Reply #1 on:
July 27, 2010, 11:37:24 PM »
Well it works…kind of. Using the setup described above I get a voltage reading of .723. So at .10V a degree (F) that should be 72.3 degrees. It seemed a bit off, I measured the output of the LM34 and it was .705 V. (The AD Raw reading was 145, the supplied voltage from the ioBridge is 5.06)
Any idea why the display reading would differ from the input reading?
Logged
Administrator
Hero Member
Reply #2 on:
August 03, 2010, 11:08:38 AM »
It could be an impedance mismatch. If so, a 100k resistor between the LM34 and the analog input may help.
Logged
wwtolman
Newbie
Reply #3 on:
August 03, 2010, 11:47:34 PM »
Tried using a 100k between the LM39 and the analog input as suggested
The display variance the widget showed was even greater than before.
Meter showed .710, display showed .793
I’ll keep trying,
Logged
Print
Pages: [
1
« previous
next »
ioBridge Community
Hardware
Hardware in General
