Author Topic: Problem reading voltage from LM35DZ  (Read 637 times)
flashpaul
« on: August 30, 2010, 11:20:25 AM »
Hi,
I am having a problem obtaining the correct reading from a LM35 temperature sensor
At room temperature it should read around 0.25v [assuming around 25 degrees C]
The Iobridge is showing a reading of 0.080v , which is too low
the Iobridge raw reading is around 18
I have connected my circuit to an Arduino and it appears to be reading correctly [raw reading is around 45]
Is there something I am doing wrong here ?
Thanks in advance
jason
    • ioBridge.com
Re: Problem reading voltage from LM35DZ
« Reply #1 on: August 31, 2010, 12:42:04 PM »
You may want to check out this thread...  sounds like a similar problem
http://www.iobridge.net/forum/index.php/topic,726.0.html
Jason Winters
ioBridge Developer
