Welcome, Guest. Please login or register.
Did you miss your activation email?
September 03, 2010, 09:23:26 AM
Pages: [1]
  Print
Author Topic: Javascript access to widget functions  (Read 2531 times)
Administrator
Sr. Member
WWW
« on: December 31, 2008, 03:09:50 AM »
We're working on a few javascript functions to give you control over your widgets.
To make the following functions work, the widget must be loaded on the webpage first (but it can be hidden, if you want)
If you want to 'execute' a widget's function in javascript, you can now use the widgetExecute function.  Use this for servo positions and X10 commands.
widgetExecute(XXXX) where XXXX is the widget ID
If you want to set the state of a digital output widget in javascript, you can now use the widgetSetState function.
widgetSetState(XXXX,Y) where XXXX is the widget ID and Y is either 0 or 1
Here is an example of using the widgetSetState function to create a pulse of a specific length on digital output pin.
I first needed to create a digital output widget with the ID of Q6Vs3RepsH6I.
Code:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<title>Pulser</title>
<script type="text/javascript">
function Pulse(WidgetID, PulseDirection, Milliseconds){
   var date = new Date();
   var curDate = null;
   if (PulseDirection==0){
      widgetSetState(WidgetID, 0);
      do { curDate = new Date(); }
      while(curDate-date < Milliseconds);
      widgetSetState(WidgetID, 1);}
   else {
      widgetSetState(WidgetID, 0);}
}</script>
</head>
<body>
<a onClick="Pulse('Q6Vs3RepsH6I',1,2000)">Positive Going Pulse</a>
<br>
<br>
<a onClick="Pulse('Q6Vs3RepsH6I',0,2000)">Negative Going Pulse</a>
<div id="ioWidgets" style="display:none;">
<script type="text/javascript">document.write(unescape("%3Cscript src='" + "http://www.iobridge.com/widgets/io.js?Q6Vs3RepsH6I' type='text/javascript'%3E%3C/script%3E"));</script>
</div>
</body>
</html>
Here I made a function called Pulse which gets passed the widget ID, the pulse direction and the length of the pulse in milliseconds.  When called, it sets the first state, waits for the time specified and then sets the second state.
There is also another function that will grab the data from a widget. It is widgetGetValue.
widgetGetValue(XXXX) where XXXX is the widget ID
It's important to note that this function will only give you the data from the widget and not the module directly. The widget will need to be set to auto-refresh if you expect to get new values in subsequent calls.  If you need to get data directly from the module, use the Data Feed API.
We'll be releasing some proper documentation soon, but this should get you started!
« Last Edit: January 28, 2009, 11:53:36 PM by jason » Logged
Administrator
Sr. Member
WWW
« Reply #1 on: December 31, 2008, 11:06:24 AM »
The widget ID is the string at the end of the widget code:
Code:
Q6Vs3RepsH6I is the Widget ID for the above widget.
Logged
mrb1090
Newbie
« Reply #2 on: January 01, 2009, 02:16:26 PM »
Thanks Jason,
Curious, to control the relay module would you use the widgetSetState or widgetExecute function?
Happy New Year,
Mike B.
Logged
Administrator
Sr. Member
WWW
« Reply #3 on: January 01, 2009, 04:14:17 PM »
Since a relay is controlled with a digital output, the widgetSetState function is the one to use.
Logged
thecapacity
Newbie
WWW
« Reply #4 on: January 10, 2009, 07:22:23 AM »
Jason,
You mention setstate should be 0 or 1 but what about for a Variable Servo Position Control Widget?
Logged
Administrator
Sr. Member
WWW
« Reply #5 on: March 02, 2009, 08:47:37 PM »
Here is some more detail on using JavaScript to control the widgets:
http://www.iobridge.net/wiki/api/javascript-widget-control-api
Logged
Pages: [1]
  Print
Jump to:
Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC
| © ioBridge Corporation | RSS Feed
